M48 out to Aim Pista Aux V settings
We are running a new AiM Pista dash off out M48. We are using the Aux V input into the ECU as a oil pressure sensor (Motec 0-5 Transducer) We set the table for A/D as per Motec East here in the US. Now, when the dash sees the ECU channels, the Aux V is a Voltmeter not pressure. Is there a way to edit the sensor values in the M48 so that they come across as pressure? Or, are the AUX names and outputs set in stone in the ECU?
Gracias!
Andrew
Gracias!
Andrew
