M48 out to Aim Pista Aux V settings
Postby Andrew C on Mon Aug 06, 2012 4:04 am
We are running a new AiM Pista dash off out M48. We are using the Aux V input into the ECU as a oil pressure sensor (Motec 0-5 Transducer) We set the table for A/D as per Motec East here in the US. Now, when the dash sees the ECU channels, the Aux V is a Voltmeter not pressure. Is there a way to edit the sensor values in the M48 so that they come across as pressure? Or, are the AUX names and outputs set in stone in the ECU? :?:
Gracias!
Andrew
Andrew C
Users browsing this forum: Google [Bot] and 2 guests
