M48 Communication Cables and Impreza Loom Adaptor
Postby QFR on Fri May 25, 2012 10:14 pm
Hi all,
I have just purchased an M48 ECU which was previously used on a Version 5/6 Impreza. I want to install this on our V3/4 Impreza. There is a MoTeC Loom adaptor box for the 5/6 here, can one be got for the V3/4 or the one I have converted?
Also the comms cable I see has been referred to as a PCI Cable. Can a standard serial cable be used or is it necessary to use a MoTeC cable as it looks like a standard serial cable to my uneducated eye.
QFR
Re: M48 Communication Cables and Impreza Loom Adaptor
Postby stevieturbo on Sat May 26, 2012 5:32 am
QFR wrote:Hi all,
You must use a Motec cable
And you'll need a new ecu connector in the patch harness box for a 97/98 as it's totally different from a 99/00
Not sure if Motec sell these separately or not, but they are available. The first link whilst it is a 4 socket connector, can still be used for 97/98 3 plug cars. the 4 plug just has an extra socket. Or you can buy a 3 plug specific socket too.
http://www.m-cal.com/Products/MC04-3690 ... B--(Yellow)
http://www.tfelectronics.com.au/PageFil ... ctors.html
http://www.diyautotune.com/diybob/index.html
Not sure how much a complete new adaptor would cost from Motec
