Splicing the RS232
Splicing the RS232
Postby Andrew C on Tue May 22, 2012 7:11 am
I am looking for options for my M48 to AIM Pista connection. Spoke to Motec and we agree that I can use my current ECU Download cable to supply the AIM, and disconnect from Aim and use the laptop when needed. Here is my question. Can RS232 support a splice? I have a few serial harnesses, and would like to use the leads out of the Aim and splice them into the serial which will plug into my ECU download/Upload harness.
Andrew
Andrew C
Re: Splicing the RS232
Postby OmarK on Wed Jul 18, 2012 12:53 pm
Splicing for example a GPS RS232 output between an ECU and MoTeC dash is possible and works fine. So it may be possible.
OmarK
Postby Holmz on Wed Jul 18, 2012 9:14 pm
OmarK wrote:Splicing for example a GPS RS232 output between an ECU and MoTeC dash is possible and works fine. So it may be possible.
I have used the Y-connectors for RS232 and they work fine for testing.
A proper splice would be better, or you would want to locktite those the little screws and stand offs as they will surely come unstuck at the worst possible time.
Postby MarkMc on Thu Jul 19, 2012 4:29 pm
You have to be a bit careful here. The communications from the M48 to the AIM is different to the M48 to the laptop. The splice will work you just have to understand that the communications to the AIM dash will stop whenever the M48 is connected to the laptop and the ECU Manager software is being used. It should not cause any problems.
