What is this?
What is this?
Postby szabyk RST on Sun May 06, 2012 5:42 pm
this is the two trigger signal from MoTec M4 to MSD Dis4....
the motec no fault code...the MSD blinks 3 (Three Blinks: Intermittent input signal)
some pictures of the error:
thanks for any help :)
szabyk RST
Re: What is this?
Postby Holmz on Sun May 06, 2012 6:15 pm
Where is that noise coming from?
That does not look helpful.
Re: What is this?
Postby szabyk RST on Sun May 06, 2012 7:39 pm
Holmz wrote:Where is that noise coming from?
that's a question :
szabyk RST
Re: What is this?
Postby stevieturbo on Sun May 06, 2012 9:04 pm
Are you trying to run the MSD directly off the Motec ?
Does the engine run ?
And to confirm, this is a scope trace of the Motec's ignition output ?
If the engine is running, is ignition timing accurate ? Is all MSD coil wiring and HT wiring kept well clear of any crank/cam trigger wiring, and better still kept away from all sensor wiring ?
Re: What is this?
Postby szabyk RST on Sun May 06, 2012 9:48 pm
hi,
this is pictures the MoTec ignition output.....
all MSD wiring is keeptd
szabyk RST
Re: What is this?
Postby Holmz on Mon May 07, 2012 2:31 am
It is either electrical or magnetic.
Are you running a condenser?
Are all the ECU sensor wires run as twisted pairs?
Re: What is this?
Postby szabyk RST on Mon May 07, 2012 2:38 pm
Holmz wrote:It is either electrical or magnetic.
the ref HALL
sync magnetic
no i not running condenser,and not twist the sensor pair... :?
szabyk RST
Re: What is this?
Postby Holmz on Mon May 07, 2012 2:58 pm
the ref HALL
sync magnetic
Well...
1) Do you understand why you want to twist the wires?
2) Do you understand why to run a condenser.
I would do #1 first and then see where you are at. Then add the condenser and you will have some before and after examples to help you understand the effect of the twisting and condenser.
It would be augmented by understanding the reason why you do that, but just following the rules gets you to the same place.
Re: What is this?
Postby szabyk RST on Mon May 07, 2012 3:18 pm
the ref HALL
sync magnetic
Well...
OK, I give the information to the installer :)
szabyk RST
Re: What is this?
Postby stevieturbo on Mon May 07, 2012 9:40 pm
And the mag sensor wires should also be shielded.
hall sensor wiring is less important, but good practice to shield them.
But most important is routing them well away and never parallel to any high voltage wiring.
And as the MSD can trigger the coils at around 500v, these too should be considered high voltage as well as the actual HT leads themselves.
Despite this problem, does the engine run, and is ignition timing as commanded on the map tables ?
Users browsing this forum: No registered users and 25 guests
