Hi
this is my 1st Motec ecu M4 pro
my engine setup as below
SR20det
GT3076R turbine
FIC 1050cc low ohm injector
Greddy intake manifold with 70mm throttle body
big FMIC kits
std cam shaft
walbro pump with 20psi w/vacuum
the problem is the air fuel ratio too rich (11af ) at idling after I change my 510cc injector to this FIC 1050cc injector .
I know we can reduce it at fuel map right , but even I reduce the loading point ( idling ) to 0 it still too rich .
but once the vacuum loading point near to 0 vacuum everything go find .
the problem stared when the loading point go below -0 vacuum .
can anyone here help me out of this problem .
Thanks a lots
