Problem error SYNC Signal
Postby super7 on Sun Jan 08, 2012 10:44 am
Hello.
I am helping a friend with his Golf III Cit-car rally car.
We have problems with the SYNC signal the coming and going as high up on the rpm.
I think the problem may have to do with the 2 teeth on the flywheel, they are about 72 degrees long 180 degrees from each other.
Ref / Sync mode we run at 11 and Crank Ref Teeth 2
Ref Sensor Type 1
SyncSensor type 4
Best regards Nisse
super7
Re: Problem error SYNC Signal
Postby stevieturbo on Mon Jan 09, 2012 12:18 am
You'd need to scope the signals to check actual signal patterns and voltage levels.
Does any of the crank/cam sensor wiring go anywhere near HT leads ?
