M48Pro losing sync
Have an early Subaru that's just been rebuild and has aftermarket cam pulleys.
Engine does sync up and start, but after that below 1500rpm getting "no sync" errors and engine isnt happy ( usually stalls )
Scoping the cam signal, generally it is a very good clean signal. But on the 3 tooth portion ( 3,1,2,1 ), the 1st and 3rd tooth give a good steady signal of similar voltage level. But the middle one is much lower, approx half the voltage.
Ive never scoped an OEM signal to compare voltages or patterns seen
Even at approx 3000rpm, the voltage level is only 2v. Sensor cannot be moved any closer to the teeth or it will hit. And further away loses signal altogether at the ecu.
Could this low voltage be enough for the ecu to lose the sync ? Would applying a sync mag level table with low mV levels be sufficient to fix it ? Other than replacing the cam wheel.
Even revving to 3-4k there appears to be no background noise levels and signal is totally clean.
