Change Logging Rate M48
Postby racehatch on Wed Dec 21, 2011 7:04 pm
I'm having trouble finding where I go in the setup to adjust the logging rate, I need to adjust my Lambda channel to 100hz.
thanks,
Sam
racehatch
Re: Change Logging Rate M48
Postby AdamW on Thu Dec 22, 2011 9:11 am
If using EMP 6.2, Logging rate is found under General setup>Miscellaneous Setup 2>Internal Logging Rate.
This setting changes the rate for all logged channels and with a M48 the max rate is 20Hz.
Motorsport Electronics Ltd.
AdamW
