Logged data
PostPosted: Tue Nov 22, 2011 3:53 am
by bbs16
Just recently started having this problem, which is I can get the internal logged data and then select Mixture map, but the problem is the bottom row of the graph rpm is all jumbled up and odd values appear in the load/map selections. And a grey error comes up with "Subscript out of range in Module MINTA20 at address 0F39:B2BB" and same story if I use another laptop.
Any Suggestions?
Re: Logged data
PostPosted: Wed Aug 15, 2012 2:59 pm
by OmarK
Is this a problem you were having with i2 when viewing a mixture map?
