Coils firing at power up
In a new M4 installation, whenever I turn the ignition on, all 4 of my coils are firing once.
If there is fuel in the cylinder the flame can go in any old direction, so I am assuming this is not normal!
M4, using LS2 coils. 4cyl, 4 coils, wasted spark, 2 ignition channels.
setup ign = 1
I have no capacitors near the coils, its using the coil harness from the donor commodore(?).
I thought it may have been because my injectors and ignition coils were powered by the same relay powering the ECU. So I added a separate relay as per the Motec diagrams, powering the injectors and coils controlled by the Fuel pump output. It made no difference.
I disconnected the M4 Ign1/2 wires between the ECU and coils, and the spark goes away.
I can do a coil test, both fire as expected. Engine starts and runs.
Noise on ground or ign signals?
Miswired somehow?
setup ign = 1
Miswired somehow?
