by lonestarrpm on Fri Nov 04, 2011 6:38 am
I had an o-scope when I was debugging my setup -- unfortunately
while it was good enough to look at the waveform -- it was horrible
for determining alignment. So I experimented.
I'm not 100% sure but I think the difference between the
71,72,73,74 or any of the #[1234] nomenclature is the
expectation of the relationship between the ref and sync.
for example the combination maybe (I have not verified)
#1 rise, rise
#2 rise, fall
#3 fall, rise
#4 fall, fall
So -- I was able to fiddle with the settings and observe the sync % to sort of figure things out.
Not the best way -- but if you are equipment challenged it just might work for you.
Mike
