5 bar map setup
ok ive just purchased the 5 bar unit from motec (53006) , now wondering how to set up the tables correctly .
1 , sensor calibration .. is that found in my "sensor setup" box , and if so i just set it to -1
2 , now it gets tricky
, 0 pressure AD value ? , does that mean i go to the "sensor cal tables" and go into "manifold pressure" , and if correct the very first box (0) i enter the value 103 and then "interpolate horizontal row "
the ECU then makes its own numbers for all of the remaining boxes .
Is this correct and am i missing something
What is the *pressure AD value mean (500/895) , and where do i set it if need be in my M2R , as i cant find anything relevant in my setup tables to enter the numbers ?
thanks brad
thanks brad
