What pins are used on M48 Connector?
Postby lonestarrpm on Mon Oct 10, 2011 1:51 pm
Where would you buy them and crimp tool?
Might be quicker to debug my wiring harness by bypassing the current
wiring and wire up my sync/ref directly.
thanks,
mike
lonestarrpm
Re: What pins are used on M48 Connector?
Postby jonathannc on Sat Oct 15, 2011 11:46 pm
Hi.
AS for M48 wiring layout that will depend on the setup it's being installed on.
for example pins 5,6,7,8 ref & sync inputs for magnetic or hall effect , that will be down to install.
I suggest provide further and better details .
if in UK crimping tools can be sauced from vehicle wiring products, Radio Spares, CPC, Farnells etc.
plugs & other things can be sauced from dataspares or local motec outlet.
thanks,
mike
jonathannc
