Diagnostics Terminology REF/SYNC
Postby lonestarrpm on Mon Oct 10, 2011 7:30 am
M48 --
On the diagnostics page I get the following
OK REF ERROR
OK NO REF
OK SYNC ERROR
OK NO SYNC
later
NOT OK SYNC STATUS
I also get 0 RPM -- which usually means no REF signal.
What I am trying to figure out is if I am actually getting
a REF and SYNC ERROR or not.
I must say if OK REF ERROR -- means there is no REF -- you would think it would be ERROR or NOT OK.
I don't have an oscope handy == but I'm working on that.
thanks,
Mike "scratching my head in Texas"
lonestarrpm
Re: Diagnostics Terminology REF/SYNC
Postby Holmz on Mon Oct 10, 2011 11:16 pm
lonestarrpm wrote:M48 --
Don't scratch it too hard.
In the link is a wedinar on reference/sync - you cannot down load it, but watch it a couple of times.
http://www.motec.com.au/webinars/webinararchive/
If all else fails:
You get the pins from you local dealer. get extras, and maybe a plug as well.
For wire - get the 22-ga Tefzel (I used www.SteinAir.com)
For the crimper - I do not recall where I got it, but mine says "Duetsch HDT-48-00"
Postby Chris Wilson on Tue Oct 11, 2011 2:52 am
That Deutsch crimper is for the MIL spec connector pins, the M48 uses the Tyco Econoseal type connector pins, doesn't it? If so the tools discussed here are the ones.
viewtopic.php?f=11&p=4714
Chris Wilson
Postby Holmz on Tue Oct 11, 2011 11:33 am
Chris Wilson wrote:That Deutsch crimper is for the MIL spec connector pins, the M48 uses the Tyco Econoseal type connector pins, doesn't it? If so the tools discussed here are the ones.
http://www.motec.com.au/forum/viewtopic.php?f=11&p=4714
You're right - now I have to find where I put that one!
Postby lonestarrpm on Tue Oct 11, 2011 4:16 pm
getting closer --
now have Ref signal -- and sync signal -- but Sync Error.
I've got a Clewett Crank Pulley -- looks to be 60 tooth with extra teeth at TDC, but the sensor is 60 degrees off.
I believe I am mode 21-24 -- but I can't find any reference to describing the difference between modes 21-24 (M48)
I've watched the webinars -- but I must have missed it somewhere if it is explained.
thanks,
Mike
lonestarrpm
Postby lonestarrpm on Fri Oct 21, 2011 4:54 am
FWIW,
I got her running.
Turned out it was missing teeth x 2, mode 72.
mike
lonestarrpm
