celica st205 pin outs motec m4
Postby jon379 on Mon Aug 08, 2011 9:21 pm
hi does any 1 have a wiring diagram with connections for a motec m4 to connect to a celica st205, also how can i find out what functions are enabled on my motec recently purchased 2nd hand and is supposed to be enabled how do i find out what is enabled serial no 9802 - 01792 any help appreciated
jon379
Re: celica st205 pin outs motec m4
Postby jon379 on Tue Aug 09, 2011 8:42 pm
can anyone help ;)
jon379
Postby Chris Wilson on Wed Aug 10, 2011 3:10 am
Chris Wilson
Postby jon379 on Thu Aug 11, 2011 11:20 am
cheers for that chris but that loom looks a bit past it and some bits seem missing off it , i have managed to acquire a daughter brd which enables me to plug my original ecu harness into it and then also plug the motec into that ,where each pin from original ecu plug corresponds with pins to motec plug making it plug n play ,i noticed motec did 1 for a st185 but was hoping one is available for st205 to make my job easier ;)
jon379
Postby MarkMc on Thu Aug 11, 2011 5:45 pm
This should be what you need.
M4 to Toyota ST205.xls
(53.5 KiB) Downloaded 1914 times
Postby jon379 on Sat Aug 20, 2011 8:15 am
thank you for the information it is a great help
jon379
