I am running an M48 with a 4 wire Lambda. We ran on a dyno and used the dyno's meter to get our mixture around 12:1. consistantly.
The Lambda sensor is a new Bosch unit from Motec, and it is visable on the ECU screen. we have advanced tuning and logging enabled.
We took the car to the track, and after the session, downloaded the file. Lambda is reading 1.00 to 1.20 across the board, which is contrary tot he dyno results. We pulled the plugs, and it looks to be running on the rich side, so we are confused.
Is the a setup in the ECU software that might cause this? If the lambda is off, will it read at all? If we run it as wideband, can we adjust the engine temp that will control the lamda function?
As a note, the engine is a Porsche 911 race engine, air cooled. And the engine temp was only 60C ..
Thanks,
-A-
