wiring diagram for MSD 6AL to M48 ecu
Mon Jun 06, 2011 1:47 pm
by fitzsi
Does anyone know where I can find a wiring diagram for an MSD 6AL wiring diagram to connect to a Motec M48 ECU
Re: wiring diagram for MSD 6AL to M48 ecu
Tue Jun 07, 2011 6:18 am
by Martin
http://www.motec.com.au/filedownload.ph ... docid=1248Be careful of ECU Ign cut for RPM limiting since the MSD sees it as a drop in RPM and it will multispark again, and with a dizzy that could send sparks to the wrong cylinder at the wrong time. Use the 6AL`s limiter chip, or do fuel cut for RPM limiting through your ECU
Tue Jun 07, 2011 8:48 am
by fitzsi
Thanks for the info.Should have typed in the full model of the MSD as it is a MSD 6AL-2.I'll have to do some more research as to whether this is a problem as I'm reasonably sure you don,t change chips.
