Bit of help with my wee rally car please.
Postby Tristan on Sun Feb 27, 2011 12:55 pm
Hi all , I have a Ford KA Rally car , I've replaced the old 1.3 engine with a 1400cc , 16v Puma motor , good bit of headwork etc , and using Motorbike Throttle bodies , and the existing M4 that controlled the old engine . I have it starting , but it's incredibly rich , black smoke on blipping the throttle , misfiring and sooting the plugs , even leaving the pistons damp on top!
I'm using the standard fuel rail and pressure regulator from the Puma , and the standard Ka fuel pump.
Before I bring it to a Motec Agent's rolling road , can I tweak the AFR , just so I can make it run a bit sweeter , to check for leaks , be they oil , coolant or indeed vacuum? And either check or calibrate the Throttle Pot , as I've wired the 'bike one into the Car's loom.
Can I just connect to the Rs232 port on my computer? The car has a lambda sensor connected .
Thanks in advance , Tristan.
Tristan
Re: Bit of help with my wee rally car please.
Postby OmarK on Mon Feb 28, 2011 8:05 am
Hi Tristan,
If your M4 has a serial number greater than 3000 then you can use a standard serial cable to connect from the M4 to your laptop. You can then download/install our latest version of M4 software. This will allow you to communicate and do some minor tuning before you take it to the dyno :)
OmarK
Postby Tristan on Mon Feb 28, 2011 8:18 am
great ,cheers , I'll check the serial number tomorrow!
and if the serial number is less than 3000...?
Tristan
Postby OmarK on Tue Mar 01, 2011 7:09 am
We have a PCI cable which is used to communicate with the < 3000 serial numbered M4s and all the M48s...
OmarK
Postby stevieturbo on Tue Mar 01, 2011 7:21 am
Poor spark could also give similar symptoms
Postby Tristan on Tue Mar 01, 2011 8:30 am
OmarK wrote:We have a PCI cable which is used to communicate with the < 3000 serial numbered M4s and all the M48s...
I've ordered one today from my Motec agent! cheers
Tristan
Postby Tristan on Mon Mar 14, 2011 7:41 am
Got it sorted , took it to myMotec man , TrackDayPerformance.ie , and we found the ECU was acting up , and wasn't getting signals from the TPS , or temp sensors etc . He fixed it ,and mapped it , running clean as a whistle now .
Oh and my 1st rally with the new engine was 2 days later , and we won our class! Happy days. :D :D
Tristan
Postby Tristan on Tue Feb 12, 2013 10:43 am
Thread revival!
How do , all
I've been pottering away at the wee Ka , stripping back all un-needed bits of Ford wiring loom. Looking at the MoTec wiring code , it mentions PATS in a few places , anyone know what this is?
  Ford KA EEC IV 60 Pin ECU
1/7/2002
OEM Used Function                      Comments Wire Colour
1 No Backup 12 Volts Constant 12 Volts Orange/Yellow
2
3 Yes Vehicle Speed Sensor Callibrate White/Blue
4 No Heater Control Mod. White/Black
5 No PATS White/Green
6 Yes PATS Loop to 0 Volts Or Aircon Press Sw Black/Red
7 Yes Water Temp Callibrate Requires resistor White/Green
8 No Fuel Pump ON Violet/Black
9 Yes AFM Callibrate Brown/Blue
10
11 No Purge VSV Black Orange
12 Yes Injector Cyl 1 With PATS Black/White
13 Yes Coolant Fan Relay Black/Blue
14 Yes Injector Cyl 4 With PATS La Relay No PATS Black/Yellow
15 Yes Injector Cyl 2 With PATS Black/Yellow
16
17 No Data Link White/Green
18 No Data Link Blue/White
19 No Data Link Grey/Violet
20 Yes 0 Volts Black
21 Yes Idle Control Black/Blue
22 Yes Fuel Pump No PATS Black/Blue
23
24 Yes Mag Sync Signal White/Violet
25 Yes Air Temp White/Violet
26 Yes Sensor 5 Volts Yellow
27 Yes Octane Adjuster Callibrate White/Black
28 No Power Steering Brown
29
30 Yes Sync 0 Volts Brown/White
31
32
33 Yes Lambda Relay With PATS Injector 3 No PATS Black/Yellow
34 Yes Injector Cyl 3 With PATS Injector 4 No PATS Black/Orange
35 No Inntruments Overheat Signal ????? White
36
37 No 12 Volts As Pin 57 Violet/Yellow
38 No PATS Grey/Orange
39 No PATS Black/Orange
40 No 0 Volts Black/Yellow
41 No PATS Violet/Black
42
43 Yes Clutch Position Sw. Callibrate Brown
44 Yes Lambda Signal White
45 No 12 Volts Constant 12 Volts Blue/Red
46 Yes Sensor 0 Volts
47 Yes TPS White
48
49 No Data Link Air Flow Meter Grey/Violet
50 Yes AFM White/Blue
51 Yes Injector Cyl 1 No PATS Black/White
52 Yes Injector Cyl 2 No PATS Black/Yellow
53 Yes Fuel Pump With PATS
54
55 Yes Ref 0 Volts Black
56 Yes Mag Ref Signal Black
57 Yes 12 Volts Violet/Yellow
58 Yes Ignition 1 Black
59 Yes Ignition 2 Black
60 No 0 Volts Black/Yellow
Tristan
Postby AdamW on Tue Feb 12, 2013 1:33 pm
PATS = Passive Anti Theft System.
You say you are looking at the Motec wiring schematic, but this is fords system, nothing to do with motec??
Motorsport Electronics Ltd.
AdamW
Postby Tristan on Tue Feb 12, 2013 8:26 pm
Sorry, I have that too, I just posted the above to show where I encountered the PATS acronym. It's an M4 in the OE Ford ECU case, with the OE Ford ECU plug.
Thank you.
Tristan
