M2R - help with settings
we have a customer with a two-rotor RX-7 FD, single turbo. The customer wanted this ECU in his car, so we purchased and installed it. The car runs, but we have two issues:
1) We need help with the injector current setting. We have a pair of low impedance Bosch 800cc injectors for the primaries, and another set of Bosch 1600cc as the secondaries. When we had a current setting of 3A, the car would misfire at partial boost and we got an "OPEN" error on the 2P injector most of time, sometimes on both injectors. We changed this to 2A, and now we are getting a "PEAK" error. What exactly do these mean and what's the procedure for nailing down the correct setting?
2) At more serious boost levels, we are getting the "MAX DUTY CYCLE" error. By switching to the Balance table view, I can see that the primary injectors are reaching or exceeding 100% duty cycle, however the secondaries are more like 5-10%. I read somewhere in this forum about a formula to populate the Balance table properly (something like % = {1/[(S/P)+1]}. Right now the balance table is 100% everywhere, which means that only the secondaries are used, right? If so, why am I seeing the primaries being maxed out but secondaries only getting 5-10%? So my question is what do I do to get the secondaries to inject more?
Thanks,
Dimitris@Rotary Beat
Thanks,
