Dual RPM - w/o input sw selection
PostPosted: Fri Feb 04, 2011 2:02 pm
by bazeng
Hi guys,
I'm wondering if I could use the DUAL RPM setup for launch control without using any input switch but instead use the motec speed input value.
ie, speed = 0, rpm limit becomes active.
Is this possible?
Re: Dual RPM - w/o input sw selection
PostPosted: Fri Feb 18, 2011 2:43 pm
by MarkMc
That is the launch control function if you have Advanced Functions enabled, i.e. an M4Pro. Launch control is an RPM limiter based on ground speed.
