Injectors settings - Denso (Power enterprise) 1000cc inj
Hi guys,
I have a set of injectors that I have removed from my Autronic ECU'd car to install into the Motec ECU'd car.
Below are the details:
Would you guys have any suggestions of what to select?
Part number:
Power Enterprise (DENSO)
TL 1000-C
195500-3650
Flow rate:
1000cc/min @ 300kpa
Coil resistance:
2.4 Ohms
Injector driver:
High - Current
Any help appreciated.
I have currently selected the closest injector to the 2.4 Ohms in the F1 list but I am wondering if there are any improvements that can be made.
Thank you
Part number:
TL 1000-C
195500-3650
Flow rate:
1000cc/min @ 300kpa
Coil resistance:
2.4 Ohms
Injector driver:
High - Current
Thank you
