Honda S2000
Honda S2000
Postby Brede on Sat Oct 09, 2010 9:23 am
Hi!
Anybody who have done Honda S-2000 engine with motec?
I am using a M4 on a S2000 in a RallyCross car,would like to know
cam and crank trigger settings if you can help me please.
Regards
Brede
Brede
Re: Honda S2000
Postby Brede on Sun Oct 17, 2010 3:27 am
FYI:
If any is doing this with M4,spare some work as i did dismantle the cam timing transmision to find
The Honda S-2000 engine have 12 teeth ref Crank wheel with mag sensor
Use the inlet cam with 3 teeth and mag sensor remove 2 teeth and coil from bosch with igniter inside.
Then it is good to go,Coil on plug stock in this engine i did not get to work.
Regards
Brede
Brede
