I am going to build an ignition module from scratch for a friend to connect to his M48 ECU. This is going to be a microprocessor controlled "smart module" that measures the coil current and sets the dwell time accordingly. Say we set the ECU dwell figure for a fixed 6mS right across the scale, regardless of rpm and battery voltage, then I read somewhere that the ECU forces a minimum coil offtime of 0.3mS What I need to know though is this - as you hit that 0.3mS gap in the pulses, does that 0.3mS then just stay constant and the 6mS hi time reduce with rpm increase, or alternatively as you =approach= that 0.3mS gap does the 6mS hi time start reducing and the 6mS/remainder mark-space reduce proportionally till you get to the 0.3mS minimum offtime.
Unfortunately I don't have access to the ECU at the moment or I would rig it up on the bench and measure it myself.
