M4 with HP laptop can't see some word on graph page.
Thu Sep 30, 2010 7:26 pm
by torque
Hi
I use M4 and install software on HP laptop but when I go to graph page. It can't see the numeral on table.
XX00, XX00 But when I open with IMB no problem.
What's is problem?
Can you help me to settle this one?
DOS run well with IBM only?
Thanks,
Re: M4 with HP laptop can't see some word on graph page.
Tue Feb 01, 2011 7:08 pm
by Motorsport Eng.
have you solved?
We have seen it on some laptop as well....
regards
Tue Feb 01, 2011 7:41 pm
by Holmz
Guessing here...
But it looks like there are some English type fonts that you might not have on the machine.
Not sure if that is the case, or how you add more language fonts if it is.
Wed Feb 02, 2011 7:07 am
by SprinterTRD
The problem is with the video system not supporting the resolution correctly. Unless there is a later video driver there is no fix for the problem.
Wed Feb 02, 2011 1:24 pm
by OmarK
I'm not sure what version of Windows you are using but you could read about this fix here and test if this helps you.
http://www.motec.com.au/forum/viewtopic.php?f=10&t=1152
