information on air conditioner M48 street car
Postby remy78 on Tue Jun 15, 2010 7:13 pm
Hello, is-it possible to use one input for the information (12V) when the air conditioner clutch is on and with this information is-it possible to increase the RCO of the idle regulation ? Thanks . Rémy
remy78
Re: information on air conditioner M48 street car
Postby Martin on Tue Jun 15, 2010 9:57 pm
Be very careful of connecting an inductive load like the AC clutch to an Dig or AT input on the ECU. The flyback voltage is very big and will damage the input in the ECU
Postby remy78 on Tue Jun 15, 2010 10:05 pm
OK, thanks for the information, but it's not really an answer for my question.
remy78
Postby SprinterTRD on Wed Jun 16, 2010 8:30 am
No, A digital input normally sits at 5V which is considered to be logic level high. Putting 12V on top of the 5V does not change anything. The digital input needs to be grounded to be active or logic low.
Postby yotamhks on Thu Jun 17, 2010 6:55 pm
very simple but a messy and prehistoric.. solution :
Get a Relay, wire it as follows:
30
chassy ground/sensor ground
87
digital input 1/2
85
air condition +12V when on
86
chassy ground
you can use a transistor to do this but i don't know which transistor would fit there.
yotamhks
