M4 Fuel Used
Hi
In Miscellaneous Setup there is a parameter for "Fuel Used Cal", I'm not sure what I have to put in here to get an output for fuel used in litres...
The help alongside states "Total Injector Flow Rate, i.e. The maximum injector flow rate x the number of injectors. If set to cc/min Fuel Used will be displayed in litres. If set to 0.001 gal/min Fuel will be displayed in gallons. If set to 0 Fuel Used will read total seconds of injector on time..."
The entry can be edited between 0 and 19999. Am I right in thinking if I enter my injector flow rate (in cc/min) x 4 (rounded to a nearest whole number), I'll get what I want which is litres used ?
Toby
Toby
