syncrelpos on M4 Pro
Hello all,
Up until a few days ago i was using group fire to fire my injectors and all was well.
Managed to get sequential injection up and running yesterday (it needed a bigger adjustment of IJPU than i was expecting) using the stock cam sensor on the exahust cam of my Mazda BP engine which is a Hall effect combined ref&sync. The car runs OK, a little rough at idle, but most importantly with no diag errors and 'Sync OK' against the sync status.
The odd thing is that when i log the data to see the syncrelpos%, to see how much it changes at high rpm, the syncrelpos is at -1% for the entire duration of the log, regardless of RPM. Im using the Motec supplied ref/sync mode no. 162 - does synrelpos only display if you're using your own custom ref/sync ?
