hi
just wondering the real difference between the 2
i look though the doc and drawing wiring loom seem to be the same apart from the 48 have 4 more injector control
as i have a m4 + m4 loom , a friend offer a m48 ecu can i use the same loom?
also the serial cable i need for the m4 and m48 to link to pc is different? anyone know the two part code for the serial cable?
apart the injector difference and size the m48 look bigger, what would or which one is better to keep
will be use on a 2 liter turbo, 3sgte running a stoker so 2.2
and are these optional traction control any good? compare to ragiclogic
thanks in advance
