Should i use a resistor box? M4
Postby RACEPAK on Tue Apr 06, 2010 8:25 am
hello everyone.
i have a honda civic with a d16 engine, and precision 780 cc injectors 2Ω .
i used to tune the car with a chipped oem ecu, but with a resistor box,
my question is... will i have any benefit of controling the injectors if i will keep the resistor box? or should i remove it ? and set the m4 to work with 2Ω injectors ?
thanks
RACEPAK
Re: Should i use a resistor box? M4
Postby DarrenR on Tue Apr 13, 2010 2:30 pm
It's better to remove the resistor pack (before tuning) as the ECU has better control of the injectors connected directly and they will open faster. They will also work at a lower battery voltage and/or a higher fuel pressure with resistors removed.
Regards,
Darren Reynolds
DarrenR
