M4 Traction/Launch control
The M4 has 2 different function settings apart from disable of course, slip control and launch control.
Is it correct that when chosen launch control the slip control will get active after the rpm range of the launch control is reached?
Is it correct to assume that I cannot use launch without slip control, only together with slip control?
/J
/J
