M4 Traction/Launch control
Postby Mr.J on Mon Mar 22, 2010 7:35 am
The M4 has 2 different function settings apart from disable of course, slip control and launch control.
Is it correct that when chosen launch control the slip control will get active after the rpm range of the launch control is reached?
Is it correct to assume that I cannot use launch without slip control, only together with slip control?
/J
Mr.J
Re: M4 Traction/Launch control
Postby MarkMc on Thu Apr 22, 2010 5:05 pm
Hello J,
You can use the Launch and Slip control independantly or both together. If you only use the launch control it will turn off as soon as the End Speed is reached and you will have no further traction control.
