NTK lambda sensor on M4
Postby Julius GE on Thu Mar 18, 2010 2:51 am
guys, can someone help me out how to wire a Motec NTK UEGO sensor from motec into M4 ecu ?
Julius GE
Re: NTK lambda sensor on M4
Postby J&R on Sun Apr 11, 2010 11:08 pm
Julius,
You can NOT Wire this type of sensor directly into an M4 it needs a Third party device to translate it Purchase a Motec Plm and it has the instructions of how to use this sensor into your M4.
Or Purchase a Motec wide band 4 wire sensor commonly known as a LSM 11
Cheers
J&R
Postby MarkMc on Fri May 07, 2010 3:18 pm
Many years ago there was an NTK device that could be used to connect the NTK wide band to an M4. The device was an NTK device not a MoTeC one, they were not very common, expensive and I do not think they are available anymore. Like J and R said, a PLM or a LSM sensor.
