M4 Base Maps
Re: M4 Base Maps
Postby AndersH on Wed Mar 01, 2017 7:01 pm
Hello
Anything for a Volvo engine? 4cyl B230 N/A
60-2 on crank(ref/Mag) and 1 sync/hall on cam
Anders
AndersH
Re: M4 Base Maps
Postby Turbofreak on Wed Mar 29, 2017 4:58 pm
Anyone Have a basemap for a Big Block 7.6L V8 naturally aspirated running an M4?
We have a street Olds Big Block with Batten heads that will hopefully push 550hp
Probably looking for injectors in the 440cc- 600cc range
Turbofreak
Re: M4 Base Maps
Postby Chucklate on Mon Nov 13, 2017 3:42 am
Hello. I am a new member and have an older M4 in a 2g eclipse gsx. Wondering if there is base maps available for 4g63 turbo. Thank you
Chucklate
Re: M4 Base Maps
Postby Kaspa on Fri Apr 06, 2018 11:13 am
Hi First time Motec owner and having my M4 serial No. 10002-07717 fitted to a Honda K20 Type R engine is there a base map available to get it started.
cheers Kaspa
Kaspa
Re: M4 Base Maps
Postby Flow on Wed Sep 04, 2019 9:00 pm
ECU: M4 Adv Tuning
Engine: NB 1.6L MX5
Turbo: K26, external two port WG
Trigger Mode: ATI Hall Multi/Missing tooth
Fuel Octane: 98 RON
Fuel Pressure: 45
Compression: 9.4
Cams: OEM
Inlet: OEM MAF delete
Exhaust: 3" straight
Ignition: OEM
Injection: 450cc RX7
Looking to compare any similar tunes especially with boost by TPS configured.
Flow
Users browsing this forum: Google [Bot] and 11 guests
