Hi Terry,
The revision number (Ax, Bx, Dx) on the sticker represents the hardware revision of the M4 board.
The early revision boards don't support all the rEF & sync modes that are available in the software
The pro option makes no difference.
Dwell time effects the coil voltage, Supply voltage at the coil effects coil voltage & spark plug gap effects coil voltage.
Have to done a dwell/voltage/current draw test using the Bosch coil & module to see that the dwell curve looks like?
Are you using a run resistor in the 12V supply to the coil?. If so why? It needs to be removed!
