M4 Base Maps
Re: M4 Base Maps
Postby Bren on Thu Feb 26, 2015 3:08 pm
Hey everyone, I hope it's ok posting in an old thread. I have a Westfield Clubman with a 16 valve 4AGE. It currently has a crappy old ECU. I have an opportunity to get a M4 for a good price, so was wondering if there is a base map for 16 valve bigport that I can use, before I fork out for the M4?
Thanks!
Bren
Re: M4 Base Maps
Postby SprinterTRD on Fri Feb 27, 2015 4:57 pm
You will need to modify the distributor to work sequentially with the M4.
The top sensor has four teeth on it, you will need to cut three of them off and use this as the SYNC input.
The bottom 24 teeth are used as the REF input.
Jump on the MoTeC Website and look at one of the "T" drawings, the setup is there for a M4
It will also be simpler to use a Bosch 026 water temp sensor and a Delco air temp sensor. Most MoTeC Dealers have them. The standard TPS will work. but dont use the switch part of it. The standard MAP sensor can also be used but a calibration will need to be done for it otherwise just use a 1 bar Delco sensor.
Are you using the standard gray injectors? They will need to be set up as PEAK & HOLD injector type.
If you use the TVIS, an output will need to be assigned as a user table, set the axis as RPM and MAP or TPS
Re: M4 Base Maps
Postby Bren on Tue Mar 03, 2015 7:02 pm
Thanks for all of that mate. Bit more involved than I realised. I'll read up on all of that and see how I go.
So the standard air and water temp sensors are not very well suited to the Motec then? I'll have a chat to my mechanic and tuner, I dare say the tuner will have the delco and bosch items in stock. If he has had much to do with Motec's he'll probably be aware of this anyway. If I can get away with using the standard MAP sensor I would like to, as I am not going to turbocharge or supercharge the engine, so I don't see why the standard unit would need replacing.
I'll have to check injectors, but at the moment I imagine it has standard injectors. In the near future though it will be getting 20 valve ITBs and bigger injectors from a 4AGZE. I imagine these will need to be set up the same as the standard ones would?
TVIS won't be an issue when the adapter and ITB go on.
Thanks for the help mate, I am guessing you have had a M4 on some kind of 4AGE?
The only other question is in regards to a base map for it. Is there one available anywhere?
Thanks heaps.
Bren
Re: M4 Base Maps
Postby SprinterTRD on Wed Mar 04, 2015 8:52 am
The standard Air temp and water temp can be used but a calibration will be needed to be done for them, The cost of a air temp sensor and water temp sensor is less hassle than trying to calibrate the standard sensors which is why I suggested its simpler to use the Bosch and Delco sensors.
Everything you have mentioned can be done ( and has been done ) with a M4 or other MoTeC ECU.
Yes, I have several 4AG's running MoTeC's however none of them are stock, also not using an M4
As for base map, Just start with the standard MoTeC map, change the REF/Sync setup to whats in the T drawing for the distributor, Find the M drawing for the Toyota Ignition module and set that up. The CRIP will be around 6 degree plus a multiple of 180 depending on which tooth you cut off.
I think the gray injector is around 2 Ohm so a injector current of 2.5A will work
Set up the TP, AT, map & ET sensor calibrations and you are ready to start tuning
You should use the TVIS as you will loose some low down torque on a bigport engine
Re: M4 Base Maps
Postby Bren on Wed Mar 11, 2015 8:03 pm
Thanks for the help mate, I appreciate it. I have had a look for the "T" drawing and couldn't find it? Perhaps I am looking in the wrong place.
I have a good tuner in Toowoomba who knows his way around a Motec, so that will certainly help. Sounds like it shouldn't be TOO difficult to sort out.
Thanks again!
Bren
Re: M4 Base Maps
Postby AdamW on Thu Mar 12, 2015 9:04 am
Bren wrote:Thanks for the help mate, I appreciate it. I have had a look for the "T" drawing and couldn't find it? Perhaps I am looking in the wrong place.
Downloads>Tech info>App info>trigger systems>Toyota 24 tooth>
http://www.motec.com.au/filedownload.ph ... docid=1280
Motorsport Electronics Ltd.
AdamW
Re: M4 Base Maps
Postby Hiro on Tue Jun 09, 2015 1:19 pm
Dear all,
I am looking for M4 base map for Toyota 4E-FE engine.
(4cylinder 1.3L twin-cam.)
Vehicle name is Starlet or
Is it available to get something at here?
Thanks in advance!
Hiro
Hiro
M4 base map for Bseries honda
Postby edwin.opie on Sun Jun 26, 2016 2:53 am
Is there anyone has abase map for B series honda engine? Thank you
edwin.opie
Re: M4 Base Maps
Postby Tunedgether on Thu Aug 18, 2016 5:18 pm
Dear,
I would like to M48 base maps for a f16d3 as found in the Chevrolet Optra.
Thank you,
Paisan
Tunedgether
Re: M4 Base Maps
Postby yanisxae86 on Mon Oct 31, 2016 11:30 pm
Hey Yurik,
i want to map my 4age 20v blacktop with COP but my ecuwas used on a cosworth. Do u or anybody here have a base map for it?
thanks Yanis
yanisxae86
PreviousNext
