5 bar map setup
Re: 5 bar map setup
Postby Sal on Sun Nov 27, 2011 10:19 am
ok let me rephrase....or see if I understand it correctly...... the 4 (or 5) bar map sensor isnt by default in the program, it has to be setup as user defined.... now if a ecu is setup to run the 300 map sensor (3 bar) and you use a 4 or 5 bar sensor..... wouldnt the output curve of that sensor be different given that the ecu already will be using the default values from the 300 (3 bar ) sensor?
or am i understanding this all wrong?
also.... in the load sites selection I am set to user defined.... how do I see that table?
Sal
Re: 5 bar map setup
Postby beefcake on Sun Nov 27, 2011 12:40 pm
i think you go to sensor values , , then you can set up values in the AD count section :?:
And i see where your coming from on the tune side of things, as mine went from a 300 table to a 500 table but somehow the tune is meant to be the same, i havnt run it yet but i dont think it would be ideal, as i just cant see it interpolating or whateva it does to be safe enough, its not a drama for me though, just one more time on the dyno :lol:
PB of 10.01@138 mph
http://www.youtube.com/watch?v=w2k_idn71ro
beefcake
