What is this?
Re: What is this?
Postby SprinterTRD on Wed May 09, 2012 3:29 pm
"I would take care of those before the resistive wires..."
You should never use solid sparkplug wires with a EFI system.
The miss fire could also be the GT101 and the missing tooth, I had a issue with a 36-1 ford trigger wheel a long long time ago.
You could change the crank sensor for a magnetic or cut off every second tooth and change the REF/Sync mode.
SprinterTRD
Re: What is this?
Postby stevieturbo on Wed May 09, 2012 11:18 pm
So if you unplug the MSD and fit their bypass, does the problem still occur ?
If you cant find the source of the problem, might just be easier to forget the MSD and fit 4 x IGN-1A coils instead ?
stevieturbo
Re: What is this?
Postby Holmz on Thu May 10, 2012 9:12 am
SprinterTRD wrote:"I would take care of those before the resistive wires..."
Actually I misspoke earlier saying... "There are 2 ways (for noise)":
Magnetic (cured with twisted pairs)
Electrical (cured with a condenser, and I am thinking of the 12V to the ECU being jerked up and down or the ground)
There is also the 3rd noise transmission method, which is often referred to as electro-magnetic or RF.
The higher frequency noise is transmitted through the air and where the shielded wires come into play.
I never knew that resistive wires were supposed to be used.
Thanks Sprinter
Holmz
Re: What is this?
Postby stevieturbo on Thu May 10, 2012 10:20 am
No idea on "resistive" wires.
But with CDI like MSD you must use spiral wound cored HT leads/wires
And on any car with electronics, resistive plugs are pretty much a must.
stevieturbo
Re: What is this?
Postby SprinterTRD on Thu May 10, 2012 2:15 pm
I probably should have said "suppression Ignition lead" which would have been less confusing!
Generally most suppression leads no matter how thay are constructed will have some extra resistance compared to a plain wire lead.
SprinterTRD
Previous
