M4 speed /dig input
M4 speed /dig input
Postby micke r1 on Fri Sep 05, 2008 12:47 am
Hi
i am going to use my dig input to logg speed in my m4 ecu ( drawing x02 )
my qestion is:
1 shall i use nr 26 on my m4 to feed the hall sensor (+8 V) ? can i feed it whit 12v ?
2 is it nessesary to use nr 27 for 0v ,can i take negative some vere else ?
/mike
micke r1
Re: M4 speed /dig input
Postby RossB on Fri Sep 05, 2008 3:32 pm
I would wire it up exactly as per the drawing as you say but the GT101 will work with a 12 V supply and earthed to ground as well.
RossB
Postby micke r1 on Fri Sep 05, 2008 5:16 pm
Ok !
will dig input 1/2 (19-20) work with a 12 V supply from GT101 aswell ?
/mike
micke r1
Postby RossB on Mon Sep 08, 2008 9:59 am
Yes they will.
RossB
