Hi there,
I have recently bought a Yamaha R6, and the ECU is a Motec M4, serial# 4333.
The bike was used in WorldChampionship SuperSport 2005 by Yamaha Germany with the rider Broc Parkes, and has not been used very much since then.
Yesterday we put it on the Dyno, and after some runs the bike was not able to start.
We connected the PC via serial-port.
While trying to retrieve the internal log, it just wrote 'Connect ECU'.
The ignition was on, and some hours before we were able to connect and adjust without problems, so we knew the cable/pc was working correct.
When we entered the Adjust-menu, a warning-signal flashed this text 'SUU connected or ECU not Enabled'
I've looked in these forums, and found some other with similar problems.
The suggestion was to use the send.exe, and then we did just that.
It send some information to the unit, and after that everything was ok.
Then we upgraded from 6.12 to 6.20, in the hope that the problem would go away.
The bike started and run just fine, but when we took the power off/on, it entered the faulty state again.
We could not start the engine, and the 'SUU Connected or ECU not enabled' displayed again.
How do I remove this error ?
The bike is not run-able, if I have to run send.exe everytime I want to use the bike.
