when the RPM goes above 4300, I get a sync error. I'm using a M48Pro
I can see in de screen the rpm starts hunting around at 4300rpm, it goes to 2000-12000 etc etc. Then I get the sync error.
I have checkt the sensor signal(with a scope) on pin 6 and 27 (Mag-sensor), I can not see a faillure!
The voltages of the sensor are;
1150rpm = +/- 2,65V
2000rpm = +/- 4.08V
3000rpm = +/- 5.88V
4000rpm = +/- 7.77V
Further I have looked into the General setup, ref sensor type. When I select 2,3,4 it makes no difference. On 5 the engine will not start.
When I select -1 the max volt is only 4500mV, This is not the solution.
The resistance of the sensor is +/- 492Ohm. Is this too low?
Also I have checked the camsignal, (1 tooth per enginecycle with a Hallsensor). The pulses are very short, but ok I think. Does Motec only counts the pulses or does it also look the pulse-time???
Thanks in advance.
Hans
