Bosch "803" injectors
Postby bbs16 on Mon Sep 21, 2009 7:38 pm
Am looking to use some Bosch 803 injectors on an M4 unit, I can see in the help that 803`s are listed for 45psi and for 75psi but am using a regulator of 3.5bar (51psi I think) are there any calculations to find the comp figure? or would the setting for 45psi be close enough? Thanks in advance Andy.
bbs16
Re: Bosch "803" injectors
Postby RossB on Tue Sep 22, 2009 9:13 am
The 45 PSI (300kPa) compensations should be close enough for you.
RossB
Postby bbs16 on Fri Sep 25, 2009 7:28 am
Thanks for reply Ross........
bbs16
