Setup parameters for Bosch 280155968 Jolly Green Giant
Postby JoeMag on Tue Mar 17, 2026 12:16 pm
Any one running these on M48? I'm having an issue with one failing flow check after limited use hours. Aircooled 911.
Current setup:
IJCU = 0.0 setup indicates 12 and 16 ohm set to 0.0
IJbc = -1 user defined table below
IJOP = 0 for sequential
battery comp table
V usec
5 2500
6 2500
7 2500
8 2120
9 1640
10 1340
11 1100
12 940
13 800
14 680
15 580
Any other setup parameters I'm missing or corrections to these?
JoeMag
Re: Setup parameters for Bosch 280155968 Jolly Green Giant
Postby Stephen Dean on Tue Mar 24, 2026 4:17 pm
Did you test these on a flow bench?
Usually the reason for an injector losing flow compared to other matching injectors is a blockage in the internals of the injectors.
