Hello
Sorry for resurrecting old tech, I figured its a shame to throw out the ecu because its old..
I am installing an M4 on a 4AGE 20V black top with a 24-1 distributor and a IEX .
IEX in is on IGN1 Pin33
IEX pins 3 4 5 6 have the appropriate ignition coil connected to them on firing order . ( 4 pin toyota cops)
Could I please have the settings that I should use for my setup?
I am thinking that for the 24 tooth wheel the ecu will measure every 24 teeth and know tdc for cyl#1
Can we trick it and also feed it cam position ?
Thank you
