Could I ask for some advice,
What I want to do is use a magnetic cam sensor on a M4 unit, however the magnet on this setup is fixed to the cam and sweeps past the sensor itself, what have done is set this up on work bench with electric motor with scope reading the output. at perhaps cranking speed am seeing 6 volts idle 12volts and 2500 revs (cam speed) around 70 volts. so is there any possibility of using this setup with Motec? as levels seem very high. Have looked for a hall sensor but due to high heat inside engine think this is a no no.
Thanks in advance, Andy........
