I would like to disable the x10 funtion of the RPM output when under 500rpm. The current release doesnt allow for it to be done. My reason is that 1uz-fe`s are quite capable of idling at 500rpm and to have the revcounter jump all over the place when you turn on the AC or use the powersteering is very annoying! A solution would be to get RPM from another source but since most cars using these engines are OEM equiped with a 1uz-fe transplant you need to be able to calibrate the RPM output to suit the revcounter. Also if the car is idling at almost exactly 500Rpm the revcounter will jump from 500 to 5000rpm continuously.
Motec,please could we have a solution for this?
