Injector errors in log for M4
Postby stownsen914 on Mon Jul 23, 2018 2:14 pm
I recently got a Porsche 968 motor that sat for many years running again. It has the same M4 and map as when it last ran years ago. After a shakedown run at the track a couple weeks ago, I downloaded the logs and found injector errors. In approx. 4.5 minutes of logs, I see a few seconds worth of errors for each injector (injector 4 had the most at 18 seconds worth). The errors seem spread out during the 4.5 minutes. There are also a couple seconds worth of Sync errors in the logs. The EMP diagnostics screen shows OK for each injector. The engine seemed to run fine from a "seat of the pants" standpoint. The injectors are older Bosch units that I had rebuilt while the engine was being rebuilt. I saved the logs from this engine's last run years ago before the car was put in storage, and there aren't any injector errors.
Should I be concerned about injector errors in the logs? Thanks.
Scott
stownsen914
Re: Injector errors in log for M4
Postby stownsen914 on Tue Jul 24, 2018 10:30 pm
I checked the EMP diagnostics again, and it reads OK for all 4 injectors. I also did the injector test for about 30 seconds and didn't notice any issues. And then re-downloaded the logs to see if any new errors show in the logs - there aren't any. This is of course at low duty cycle. Does the engine need to be running to properly test this?
stownsen914
Postby SprinterTRD on Wed Jul 25, 2018 10:53 am
The only time logging starts is when the engine is running.
If it is a old loom then replace the injector connector pins also have a look at drawing Z05
SprinterTRD
Postby stownsen914 on Wed Jul 25, 2018 11:35 pm
Thank you SprinterTRD. I poked around on the Motec site and googled, and can't find drawing Z05. Where should I look for that?
stownsen914
Postby David Ferguson on Thu Jul 26, 2018 2:31 am
Here is the Z05 drawing:
MoTeC USA Z05.pdf
Crimping Details for 36-pin connector
(69.1 KiB) Downloaded 1073 times
Users browsing this forum: No registered users and 49 guests
