Output Throttle Position Switch threshold via Aux?
Postby lonestarrpm on Wed Oct 19, 2016 4:31 am
I'd like to toggle some warning lights on the rear of the car upon throttle lift.
How would I map the TPS value below threshold crossing to an Aux switch.
It could be a pulse or fine to be on below X% as I will be sending it into a timer
that controls an LED flasher.
My car is pretty high compression, and I can often engine brake without braking before turn in sometimes
which catches folks off guard during HPDE events.
thanks,
Mike
lonestarrpm
Re: Output Throttle Position Switch threshold via Aux?
Postby AdamW on Thu Oct 20, 2016 3:50 pm
Use an aux table, set the Y axis as TP and for the X axis you could use some other condition like RPM or ground speed so that the brake light is not on when you're idling around pits/start line etc.
Motorsport Electronics Ltd.
AdamW
