AdamW wrote:If you have "advanced tuning" enabled In the Motec software you can select what type of sensor/controller you have connected including a "user defined" choice.
on the few that I have done I have always needed to mess around a bit either adjusting the user defined table in the motec or reprograming the analog output of the controller to get the "lambda" reading in the motec to match the display on the controller.
AdamW wrote:No the wideband input is not 0-5v on the M4, I'm pretty sure the 10bit adc only covers a range of about 1.2v. The F1 help file on one of the wideband setup pages incorrectly suggests it is 0-5v but it is definitely not on any that I have tested. Note however I have never tested one of the more recent 3000+ serial numbered ecus so there is a small chance the newer versions accepted 5v.
