by Davin on Tue Jan 22, 2013 12:51 pm
Sorry for the delay. I had to sort out a lot of things in my life and unfortunately my car had to go on the back burner. I had to pull my engine and fix other things before I could tackle the tuning stuff. Anyways, here are the CDL3, M2R tuning and logging files. I have all the options, with outputs for 4 Bosch ignition coils and a Mac boost controller. I also have 6 1000cc injectors; 2 in the primaries and 4 in the secondaries Y'ed together. Also have a 32 tooth crank sensor. Rotaries are so delicate and I do not want to have to redo everything because the boost control option was not set up right or it did not have a close loop. Again, thank you for the outstanding customer service. I do not know where I will be without you guys and my car hangs in your balance!
- Attachments
Batmobile CDL3.C13
- (489.88 KiB) Downloaded 1630 times
Batmobile Tuning.T62
- (9.92 KiB) Downloaded 1643 times
Batmobile Log File.ldx
- (290 Bytes) Downloaded 1638 times
Davin on Tue Jan 22, 2013 1:31 pm, edited 2 times in total.
1993 Mazda RX7 | 13B-REW | T04Z | M2R (w/ logging & lambda) | CDL3 Track Kit
